How to send file to ftp with Simcom 900d
pedja089
Junior Member level 1
I have a Simcom 900D with firmware 1137B06SIM900M64_ST, that supports FTP.
But no matter how I tried to send a file, always get a net error. The same error also with http.
I don't understand how to use the AT + SAPBR
I managed to send file:
AT+CGEREP=1
OK
at+cipmux=1
OK
AT+CREG=1
OK
AT+CGREG=1
OK
AT+CGATT=1
OK
AT+COPS?
+COPS: 0,0,"YUG 03"
OK
AT+CSTT="gprsinternet","mts","064"
OK
AT+CIICR
OK
AT+CIFSR
172.30.7.93
AT+CIPSTART=0,"TCP","****",21
OK
0, CONNECT OK
+RECEIVE,0,322:
220---------- Welcome to Pure-FTPd [privsep] [TLS] ----------
220-You are user number 2 of 1000 allowed.
220-Local time is now 08:13. Server port: 21.
220-This is a private system - No anonymous login
220-IPv6 connections are also welcome on this server.
220 You will be disconnected after 15 minutes of inactivity.
at+cipsend=0
> User *****.com
0, SEND OK
+RECEIVE,0,58:
331 User ******.com OK. Password required
at+cipsend=0
> Pass*****
0, SEND OK
+RECEIVE,0,105:
230-User ***.com has group access to: **
230 OK. Current restricted directory is /
at+cipsend=0
> pasv
0, SEND OK
+RECEIVE,0,50:
227 Entering Passive Mode (**,147,240,**,32,54)
AT+CIPSTART=1,"TCP","**.147.240.**",8246
OK
1, CONNECT OK
at+cipsend=0
> stor simcom900d muxip.txt
0, SEND OK
+RECEIVE,0,30:
150 Accepted data connection
at+cipsend=1
>test text
1, SEND OK
at+cipsend=0
> bye
0, SEND OK
+RECEIVE,0,21:
500 Unknown command
AT+CIPCLOSE=1
+RECEIVE,0,9:
226-File successfully transferred
226 131.780 seconds (measured here), 0.46 bytes per second
1, CLOSE OK
AT+CIPCLOSE=0
0, CLOSE OK
AT+CPOWD=1
+PDP: DEACT
NORMAL POWER DOWN
But not using FTP AT commands.
Does anyone know how to send the file to the ftp using modem ftp command, or has some advice, suggestion?
Thanks
Here is HTTP/FTP AT Command list
  • an_sim900_ip_application note_v1.00_draft.pdf
AT
OK
AT+CGDCONT=1,"IP","orangeinternet","192.168.71.35" ,1,1
OK
AT+CDNSCFG="158.043.192.001","158.043.128.001"
OK
AT+CSTT="orangeinternet","",""
OK
AT+CIICR
OK
AT+CIFSR
10.52.83.134
AT+CIPSTATUS
OK
STATE: IP STATUS
AT+CIPHEAD=1
OK
AT+CDNSORIP=1
OK
AT+CIPSTART="TCP","212.157.119.102","21"
OK
CONNECT OK
+IPD65:220-************************************************** *********
+IPD38:220- PLASTIC OMNIUM SYSTEMES URBAINS
+IPD6:220-
+IPD65:220 ************************************************** *********
(ENTER)
>MESSAGE
CTRL z
SEND
OK
your your service provider gprs port no and access point
That isn't a problem. That way I can send the file.
I wrote a program for pic to send files to FTP using the above, but takes about 8K.
So I thought I use commands like AT + FTPPUT and similar.
But I can not make them work...
