/*Header*****************************************************
Microcontroller=16f877
Clock=10 Mhz
Project Title:Air Pollution Control Using GSM/GPRS
Developed By:Sathiesh Kumar.V
Date:31/01/2010*/
void Calculation(unsigned int ) ;
void Gsm_SMS_Init();
void Gsm_SMS_Read();
void Gsm_SMS_Send();
// LCD module connections
sbit LCD_RS at RB4_bit;
sbit LCD_EN at RB5_bit;
sbit LCD_D4 at RB0_bit;
sbit LCD_D5 at RB1_bit;
sbit LCD_D6 at RB2_bit;
sbit LCD_D7 at RB3_bit;
sbit LCD_RS_Direction at TRISB4_bit;
sbit LCD_EN_Direction at TRISB5_bit;
sbit LCD_D4_Direction at TRISB0_bit;
sbit LCD_D5_Direction at TRISB1_bit;
sbit LCD_D6_Direction at TRISB2_bit;
sbit LCD_D7_Direction at TRISB3_bit;
// End LCD module connections
unsigned char ch; //
char Receive;
unsigned int adc_rd; // Declare variables
char *text; //
long tlong; //
unsigned int i,j;
char return_gsm[2];
char Gsm_Receive[100];
char Gsm_Msg[10];
char uart_rd[]="AT";
char uart_rd1[]="AT+CMGF=1";
char uart_rd2[]="AT+CMGR=1" ;
char uart_rd3[]="AT+CMGS=";
char Mobile_No[]="+919444721638" ;
char Send_Msg[]="@ON";
void main()
INTCON = 0; // All interrupts disabled
ADCON1 = 0x82; // A/D voltage reference is VCC
TRISA = 0xFF; // All port A pins are configured as inputs
TRISC=0x80;
Delay_ms(2000); // Rest of pins are configured as digital
UART1_Init(9600); // Initialize UART module at 9600 bps
Delay_ms(100); // Wait for UART module to stabilize
Lcd_Init(); // LCD display initialization
Lcd_Cmd(_LCD_CURSOR_OFF); // LCD command (cursor off)
Lcd_Cmd(_LCD_CLEAR); // LCD command (clear LCD)
text = "Air Pollution "; // Define the first message
Lcd_Out(1,1,text); // Write the first message in the first line
delay_ms(500);
text = "Sensor Value"; // Define the second message
Lcd_Out(2,1,text); // Define the first message
delay_ms(500);
text = "GSM"; // Define the third message
while (1)
Lcd_Out(1,1,text); // Define the first message
delay_ms(500);
Gsm_SMS_Init();
void Gsm_SMS_Init()
if (UART1_Tx_Idle() == 1)
Lcd_Out(2,1,"AT"); // Define the first message
delay_ms(500);
for(i=0;i<=1;i++)
UART1_Write(uart_rd[i]); //AT
UART1_Write(0x0D); //Enter
//delay_ms(5000);
while(1)
Lcd_Out(2,1,"In while"); // Define the first message
delay_ms(500);
if (UART1_Data_Ready())
{ // If data is received,
Lcd_Out(2,1,"In IF"); // Define the first message
delay_ms(500);
for(i=0;i<=1;i++)
return_gsm[i] = UART1_Read(); // read the received data, Received OK
Lcd_Out(2,1,"OK"); // Define the first message
delay_ms(500);
/* UART1_Write(return_gsm[0]);
Lcd_Out(2,1,"OK RESEND"); // Define the first message
delay_ms(500);
Lcd_Cmd(_LCD_CLEAR); */
// UART1_Write(return_gsm[1]);
/*if(return_gsm[0]==0x4F && return_gsm[1]==0x4B)
for(i=0;i<=8;i++)
UART1_Write(uart_rd1[i]); //AT+CMGF=1
Lcd_Out(1,1,"AT+CMGF=1");
delay_ms(500);
for(i=0;i<=1;i++)
return_gsm[i] = UART1_Read(); // read the received data,OK
Lcd_Out(2,1,"Received OK");
delay_ms(500);
}Last edited by bryan1; 1st January
