How to send 1 bit command into ATMEGA128?
bianchi77
California
Guys,
I tried to send
PORTA.0 = 1;
but the compiler gives me an error.
I got this error :
../main.c:13:1: error: expected ';' before numeric constant
Any ideas ?
thanks
Guys,
I tried to send
PORTA.0 = 1;
I got this error :
Any ideas ?
thanks
Assuming that you are using gcc
As I learned somewhere on avrfreak, I use macros add this just below #include
#define SETBIT(x,y) SETBITS((x), (BIT((y))))
Then use it as
SETBIT(PORTB, 2);
SETBIT(PORTD, 3);
and here are some more macro you will love to see
#define BIT(x) (1 << (x))
#define SETBITS(x,y) ((x) |= (y))
#define CLEARBITS(x,y) ((x) &= (~(y)))
#define CLEARBIT(x,y) CLEARBITS((x), (BIT((y))))
#define BITSET(x,y) ((x) & (BIT(y)))
#define BITCLEAR(x,y) !BITSET((x), (y))
#define BITSSET(x,y) (((x) & (y)) == (y))
#define BITSCLEAR(x,y) (((x) & (y)) == 0)
#define BITVAL(x,y) (((x)>>(y)) & 1)
Hope this help........
Then use it as
SETBIT(PORTB, 2);
SETBIT(PORTD, 3);
thanks for replying,
if I want to
#define RS = PORTB.0 ?
how can I do that ?
thanks
can it be :
#define RS SETBIT(PORTB, 0);
thanks
I'm using AVR studio 4 and c....
I tried to define like this :
#define rs(a)  (PORTB = (PORTB & ~_BV(PB0)) | ((a) << PB0))
#define rw(b)  (PORTB = (PORTB & ~_BV(PB1)) | ((b) << PB1))
#define en(c)  (PORTB = (PORTB & ~_BV(PB2)) | ((c) << PB2))
and use it
rs(0);
delay(1);
rs(1);
am I right on my define ? I can see on simulation but can not see on my logic analyzer ??
I tried to send :
void lcd_command(unsigned char comm) // function to send command to LCD
lcd_data_pin=comm;
en(1);
rs(0);
rw(0);
_delay_ms(10);
en(0);
lcd_command(0x01);
I can't see any response on my logic analyzer, did I miss something here ?
I think rs is for LCD, right?
If so, you can define rs to be connected at PORTB 0, but need not to use setbit in define, actually I am also trying to learn and a couple of days away from LCD, give me some time I will dig up google.
OK found that, I am sorry but I have not used atmel studio, have a look at this address
http://winavr.scienceprog.com/example-avr-projects/avr-gcc-4-bit-and-8-bit-lcd-library.html
No need to thanks dear, you can always click helped me button
Gaurav
I think the problem is with this line #define RS PORTB.0
I don't know AVR Studio 4. In mikroC we use something like this #define RS PORTB.F0. You have to check some AVR Studio 4 examples which will show how to define a bit.
Also try this
sbit RS = PORTB.0;
RS = 0;
RS = 1;
Also try this
sbit RS = PORTB.0;
RS = 0;
RS = 1;
ok I'll try, it looks like in MCS51 on keil with sbit...
should be like this : #define lcd_data_pin = PORTD, I missed "="
thanks
I got the answer https://www.edaboard.com/blog/861/
it's not working by the time I send en = 1
Please find the code attached
I tested outside the function, it's working:
 while(1)
	   en = 0;
	   _delay_ms(30);
	   en = 1;
	   _delay_ms(30);
       rs = 0;
	   _delay_ms(30);
	   rs = 1;
	   _delay_ms(30);
       rw = 0;
	   _delay_ms(30);
	   rw = 1;
  • Atmega128.zip
Please see the screen shot :
sbit RS at PORTB.0;
I got error with that line...
I struggle with these codes and it seems that there's no response, anybody has ideas ?
#include <avr/io.h>
#include <util/delay.h>
 //structure to allow bit field operations, name conversions: PORTA.0 -> PORT_A.b0  PORTB.7 -> PORT_B.b7
typedef struct{ uint8_t b0:1;
                uint8_t b1:1;
                uint8_t b2:1;
                uint8_t b3:1;
                uint8_t b4:1;
                uint8_t b5:1;
                uint8_t b6:1;
                uint8_t b7:1; } bits;
// define all the ports of your microcontroller, add more ports depending on the available mcu ports
#define PORT_A (* (volatile bits *) &PORTA)
#define PIN_A (* (volatile bits *) &PINA)
#define DDR_A (* (volatile bits *) &DDRA)
int main (void)
	DDRA = 0xFF;
	//lcd_ini();
  while(1)
	    PORT_A.b0 = 0;
		_delay_ms(50);
		PORT_A.b0 = 1;
