bikashh
Full Member level 5
dear friends i want to detect the AC voltage 230V(India) from the genset output using a mcrocontroller LPC2368. can anybody help me.... how to do it?
thanks in advance
thanks in advance
Use a step down transformer & bridge rectifier to convert it to dc voltage,
then adjust to output of the potentiometer to about say, 4 volts DC for 230 volts AC.
This way the output of the potentiometer will vary along with the generator voltage.
You can easily connect an ADC to measure the output of the potentiometer.
example:
AC voltage = potentiometer output x 230 / 4
bikashh, your procedure is correct.
Sahu, you're right.
---------- Post added at 20:13 ---------- Previous post was at 20:12 ----------
Sahu, you're right.
