layoutdude
Junior Member level 3
Help with Hyper/lynx
Greetings all!
I have run into a small problem with H-lynx that I'm hoping somebody can help me understand.
I am trying to simulate a DDR data route (just one for now). The part is a Micron MT46V16M16TG which supports two different drive output strengths (termed DQ_FULL and DQ_HALF in the IBIS model).
You are supposed to be able to select drive strength (the IBIS file includes a [Model Selector] section), but I can find no way to select which model to use in H-lynx, it only provides me with pin numbers or signal names...
I have worked around the problem by copying the file and making one that is DQ_FULL and one DQ_HALF, but this seems ridiculous since H-lynx should be able to give the option.
Am I missing something, or is H-lynx really this limited?
Greetings all!
