sensen9966
Junior Member level 3
For some structure, for example, a planar F antenna, with the ground in the same plane. so the ground is also a part for resonator and radiation. like the picture attached.
so i want to simulate and see which part is the main radiation part.
sure most of the simulator can display the far field. but which can display that with the structure?
seems like ansoft designer can do this work for planar case. but it display the total far field, we can't see and know exactly which part of the structure radiate more than the other part. from most of the case, the far field radiation center is near the total structure center. i am even not sure the far field display is absolutely matching the structure or just in the center of the total structure.
so how to tell which part of the structure is the main radiator.
thanks in advance.
thanks in advance.
