How to scale the x axis in cadence spectre?
eejli
cadence calculator xval
Say sweep parameter x and get the Vout vs. x waveform.
But I actually need the x axis to be 0.05x,i.e., a waveform with 0.05x vs. Vout.
Tried around and cannot find a way to do it.
Can anyone help me?
Thanks.
xval cadence
Plot Vout vs. x wavwform.
Use AWD calculator. Click "wave" button in calculator window and after that second click on Vout waveform in Waveform window.
In calculator you will see something like "wavev12s1i1()"
Then in thr calculator window select "Special Functions" -> xval
Then multiply it by 0.05 and plot.
Next select "Axis" -> "Xaxis" -> "Plot vs." and scroll to xval(wavev1.....
Click OK.
That's all.
Reactions: sharezhao
    eejli
    sharezhao
spectre calculator xval
Is there a way to do it within the calculator ?
I to find the value of gm when the output is a given value.
cadence calculator cross function
You can plot x*0.05 and other graphcs on a same window and select a x*0.05 for x-axis (instead of independant variable) from x-axis menu.
finger widt cadence multipler
click on x-axin u can change properties in winodw
pv function+calculator+cadence
I am trying to plot Ron resistance from the results browser for different widths of a transistor. However, the parameter which has been swept by Parameteric analysis is "Number of fingers" so Ron is plotted against No. of fingers instead of width.
So, i want to multiply the x-axis by width of one finger (2um)....i have been trying the steps mentioned by Fom....but they dont work for me...
i do the following:
1. right click on Ron in results browser to plot Ron vs fingers
2. send the waveform to the calculator..but it is not wave1s..()...but an expression like pv("/M0" "ron" ?result "dcOpInfo-info")
3. I take xval of above... multiply it by 2...and then plot...i get a linear waveform between the original number of fingers and the multiplied version...
4. Now i go back to the original graph, select the x-axis and search in plot vs. drop down menu...but i dont see the xval....among the choices...
Please solve this problem...its so annoying...!!
Regards,
cadence spectre calculator help xval
i do the following:
Regards,
U can directly do parametric sweep for width. give width as variable and sweep it.
calc scale x axis
You can use "cross" function to get the x value when the output is a given value.
