[SOLVED] How to save the changing of AT+IPR=9600 on GSM modem??
saesaria
Member level 1
Indonesia
I have GSM modem, the AT-Command is compatible with wavecom modem.
The default baudrate is 115200 and I changed it to 9600, after I re-power the GSM modem, the baudrate has came back to default.
how to save the last configuration using AT-Command?
Thanks
---------- Post added at 15:55 ---------- Previous post was at 14:44 ----------
solved!
I didn't know that it's so simple to do, after changing, just type the following command
AT&W
Then it'll give the return as OK
see on page 51
