syn some blocks , BLK1.BLK2,BLK3 and do DFT,DFT input is scan_si,scan_en, and out is scan_so. And do the syn of the top module ,use 2 way to get 2 results
(1)Use BLK1.BLK2,BLK3 ddc as library to read ,then set_dont_touch BLK1.BLK2,BLK3, after syn to get coverage ,only 38%。 BLK1. BLK2, BLK3 port has no change.
(2)Read BLK1.BLK2,BLK3 netlist,then set_dont_touch BLK1.BLK2,BLK3,after syn to get coverage 99%,but BLK1. BLK2, BLK3 port add test_si,test_so.And scan_si, scan_so will no function
How to modify it , thanks
