[SOLVED] How to run a loop for a certain amount of time?
ADGAN
Full Member level 5
Full Member level 5
Hi! How can I run a loop for a certain period of time? suppose I want to run a for loop for 10 seconds. What is the calculation to determine the number of iterations?
Re: How to run a loop for a certain amount time?
in general,every MCU has clock and timer.
you can use the timer to count,for example you use a timer with 1s interrupt,this meanings the interrupt service routine will execute every 1s.set a counter in the ISR:
counter++;
set a flag when counter equals 10
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
void ISR()
   counter++;
   if(counter>=10)
          flag_10s=0x1;
void main()
    while(1)
        if(flag_10s)
              //put your code here
Thanks for the reply. But how do I set a interrupt to occur every 1s? Also what is 0x1 in flag_10s?
I suppose you are using PIC
Then, use Timer1 oscillator mode
Read Microchip AN580 Application note
But I'm using timer1 to count the pulses, can't I use timer0 ?
Use timer1 as it is 16 bit timer. setup timer1 to interrupt every 500ms. For 10 sec counter will be 20. In while(1) loop make another loop like
Code C - [expand]
while(counter <= 20){
    //code to loop
Which PIC are you using?
I'm using PIC16F887. But the problem is I'm using timer1 to count pulses. What I want to do is count pulses for 10s.
This code is for PIC16F, Timer 1, 4 MHz Fosc.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
unsigned char tick = 0;
//Timer1
//Prescaler 1:8; TMR1 Preload = 3035; Actual Interrupt Time : 500 ms
//Place/Copy this part in declaration section
void InitTimer1(){
  T1CON  = 0x31;
  TMR1IF_bit = 0;
  TMR1H = 0x0B;
  TMR1L = 0xDB;
  TMR1IE_bit = 1;
  INTCON = 0xC0;
void Interrupt(){
  if (TMR1IF_bit){
        if(++tick == 20){
        tick = 0;
        TMR1IE_bit = 0;
        //Enter your code here
        TMR1IF_bit = 0;
        TMR1H = 0x0B;
        TMR1L = 0xDB;
//call InitTimer1() whenever you want to start 10 seconds timer
if(tick > 0){
    //code to run for 10 seconds
else if(tick == 0){
    //code to run at other times
Then use **broken link removed**.
You may also use Timer2
Thanks. Is this correct? This exits the loop after 10s.
#define TMR0_PRESET   133          //Precalculated; TMR0 interrupt freq = 1KHz
/* Global Variables */
volatile unsigned int skptmr1;     // A skip timer variable
int i;
void main()
  OPTION_REG = 0x3A;
  TMR0 = TMR0_PRESET;
  INTCON.T0IF = 0;               //Clear TMR0 interrupt flag bit.
  INTCON.T0IE = 1;               //Enable TMR0 as an interrupt source.
  INTCON.GIE = 1;                //Enable interrupt operation.
                                   //Initial time delays
  skptmr1 = 1000;                  //1000-ms delay
  while(1)
    if(skptmr1==0)                 //If 1000ms has passed,
      for(i=0;i<10;i++){
      skptmr1 = 1000;              // restart the delay and
/* Interrupt Service Routine */
void interrupt(void)
  if(INTCON.T0IF)
    TMR0 = TMR0_PRESET;       //Load TMR0 with a preset value so that interrupt
                              // frequency is 1000x per second
    if(skptmr1)               //If skip timer variable is not yet 0,
      --skptmr1;              // decrement it
    INTCON.T0IF = 0;                 //Clear TMR0 interrupt flag.
  return;
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
volatile unsigned int skptmr0;     // A skip timer variable
int i;
void main()
  OPTION_REG = 0x3A;
  TMR0 = TMR0_PRESET;
  skptmr0 = 10000;                  //1000-ms delay
  while(1)
        if(skptmr0 == 0){
    else if(skptmr0){
  if(T0IE && T0IF)
  return;
Reactions: ADGAN
    ADGAN
inside the main loop, it should be:
  while(1)
    if(skptmr1==0)                 //If 10000ms has passed,
      skptmr1 = 10000;              // restart the delay and...
      //...run the task that you want here
Note that this assumes that the TMR0 module generates an interrupt every 1 ms, so that when the skip timer variable skptmr1 is reset to 10000, it will generate a delay of 10 seconds
Reactions: ADGAN
    ADGAN
Sorry Jayanth I didn't see your code. Thanks for the help jayanth & themask.
I tested the code by placing an LED to lit. But it didn't work
int i;
void main()
  OPTION_REG = 0x3A;
  TMR0 = TMR0_PRESET;
  TRISA.RA0 = 0;
  while(1)
        if(skptmr0 == 0){
        PORTA.RA0 = 1;
  if(T0IE && T0IF)
    if(skptmr0)               //If skip timer variable is not yet 0,
      --skptmr0;              // decrement it
  return;
Ok I put OPTION_REG.T0CS= 0; after LED is turned on. Now its always lit.
while(1)
        if(skptmr0 == 0){              //Blink the LED every 1000-ms
          skptmr0 = 1000;              //LED connected to RA0 pin
          PORTA.RA0 ^= 1;
When skptimer0 becomes 0 you have to stop the timer.
Technically, the TMR0 doesnt stop; it just keeps running.
You either reset the skip timer variable to start another delay, or disable the TMR0 interrupt, which generally would not make sense.
Still it didn't work. This is the latest code.
int i;
void main()
  OPTION_REG = 0x3A;
  TMR0 = TMR0_PRESET;
  TRISA.RA0 = 0;
        if(skptmr0 == 0){
        PORTA.RA0 ^= 1;
       INTCON.T0IE = 0;
  if(T0IE && T0IF)
  return;
hello,
If you disable the interrupt ,it doesn't works more than once !
and use also an infinite loop : do { ... } while(1);
int i;
void main()
  OPTION_REG = 0x3A;
  TMR0 = TMR0_PRESET;
  TRISA.RA0 = 0;
do
   if(skptmr0 == 0)
   PORTA.RA0 ^= 1;
  skptmr0 = 10000;
while(1);
  if(T0IE && T0IF)
  return;
Another way, is to do the job by only the interrupt,
and an empty infinite loop in the main.
int i;
void main()
  OPTION_REG = 0x3A;
  TMR0 = TMR0_PRESET;
  TRISA.RA0 = 0;
while(1)
 // let's the interrupt do the job
  if(T0IE && T0IF)
   else
        PORTA.RA0 ^= 1;
      skptmr0 = 10000;
  return;
an other way ....
