saraheem
Newbie level 5
I am using AT89s51 and programming with embedded C (Keil uVersion4 demo version).
I am writing a program that has a number of routines of which one is called sig_ctrl(). I am also using Interrupt 0 in my proj.
My question is this:
After the ISR is executed i want my program to ALWAYS continue executing from the start of sig_ctrl() routine only and should NOT return to where the program was being executed prior to the interrupt was sensed. If i use a jump (i.e. calling sig_ctrl() ) statement, then the uC will still be inside the ISR only, which i dont want to happen as this might cause trouble. How can this be done...? Pls give ur ideas...
Thank you...
Thank you...
