How to replicate a design 500 times using VHDL?
lahrach
Full Member level 3
Hello friends,
I want replicate a design 500 times in order to occupy all the FPGA area, how can I do it with VHDL ?
the port map of 500 designs is a tedious operation!
best regards
Re: VHDL trick
Should be easy using vectored port signals and a generate statement in the architecture.
Re: VHDL trick
hi FvM
Can u give more explanations if it is possible can u give an example with a design replicated 4 times.
FL
Re: VHDL trick
package top_ent_package is
  type data_array_t is array(0 to 3) of std_logic_vector(7 downto 0);
end package;
entity top_ent is
 port (
  TOP_ip    : in data_array_t;
  TOP_op    : out data_array_t
end entity top_ent;
architecture rtl of top_ent is
begin
  ents_gen : for i in 0 to 3 generate
    my_inst : some_entity
    port map (
      input    => TOP_ip(i),
      output   => TOP_op(i)
  end generate ents_gen;
end architecture rtl;
This generates 4 entities with each one being connected to a separate input and output
