Oct 24, 2008 #1 M mannnish Full Member level 3 Joined Aug 6, 2006 Messages 154 Helped 5 Reputation 10 Reaction score 2 Trophy points 1,298 Activity points 2,235 flash memory repair hi, i think my usb flash memory storage is damaged. please help me how to repair it?
Oct 29, 2008 #2 stabby21 Junior Member level 2 Joined Oct 21, 2008 Messages 22 Helped 1 Reputation 2 Reaction score 0 Trophy points 1,281 Location Philippines Activity points 1,392 repair flash memory does your pc still recognizes it? I mean as a hardware? If so then it is repairable.
Oct 29, 2008 #3 M mannnish Full Member level 3 Joined Aug 6, 2006 Messages 154 Helped 5 Reputation 10 Reaction score 2 Trophy points 1,298 Activity points 2,235 repair usb memory it can be detected....but i cant format it, or check its volume, open it from any place even not from from dos mode.
Oct 30, 2008 #4 stabby21 Junior Member level 2 Joined Oct 21, 2008 Messages 22 Helped 1 Reputation 2 Reaction score 0 Trophy points 1,281 Location Philippines Activity points 1,392 how to fix usb flash memory use the software included in it to format it in a low-level format. Maybe it is affected by a virus that destroys it's allocation table. if it still won't work. reheat the pcb using a hot air solder, then use a low-level format
Mar 7, 2011 #5 R romeyleh Newbie level 1 Joined Mar 7, 2011 Messages 1 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,284 Re: repair flash memory stabby21 said: does your pc still recognizes it? I mean as a hardware? If so then it is repairable. Click to expand... Hi, my pc still recognizes my flash memory? what i do to repair my flash memory?
