deathwaltz
Hi~
I want to do a fast simulation by removing a complex module (CALC). Then I used generate statement like this below:
generate
if (fast_sim = = 1) begin
CALC u_calc(
end
endgenerate
However, I find that I can't refer the u_calc module in SIM_TOP which needs to defparam a parameter in u_calc module.
I have tried
u_fpga_top.u_calc.XXXX and
u_fpga_top.genblk1.u_calc.XXXX which according to modelsim generated signal name
Both will cause error Unresolved defparam reference to u_calc or genblk1.
So I want to ask, what the right format I should use. Or is there another way to get the job done.
Generate the module conditional
if the module is generated, defparam one parameter inside in SIM environment.
Thank you very much!:grin:
Ray
generate
CALC u_calc(
end
endgenerate
I have tried
Ray
