How to reduce the RC size in a low pass filter?
surianova
Advanced Member level 1
ASIA
hi all,
I want to design a low pass pass filter with R=100k and C= 100 nF. I found out this RC will take a lot of space in the chip. Anyway to reduce like using GM -filter?
Re: RC
What do you need it for?
Maybe you can use a gain stage and use its Miller Capacitance,
Re: RC
Well the thought of adopting GM-filter is a good choice and the other sugestion of using miller cap is also good.My suggestion is to go for gm-filter.u can use the o/p impedance of the mosfets for this cause.if that is not enough u can use cascoding techniques to increase the R and decrease the C .
