How to reduce the I and Q mismatch?
dinesh agarwal
Full Member level 3
Hyderabad India
there is a amplitude mismatch of about 100mV.
the output is at 2.4 Ghz
how to reduce this amplitude mismatch
what is the reason once the circuit is symetical
vfone
Advanced Member level 5
Re: I and Q mismatch
I/Q Amplitude mismatch appear if:
- Unbalance in the RF splitter used to divide the incoming RF signal equally between the I and Q paths which may introduce gain differences.
- The quadrature 90° phase-splitter used to generate the I and Q Local-Oscillator (LO) signals that drive the I and Q channel mixers may not be exactly 90°. Furthermore, there might be differences in conversion losses between the output ports of the I and Q channel mixers.
- Amplitude mismatch appear also if the filters and ADCs in the I and Q paths are not perfectly matched.
GVVIN
Use 1% tolerant components in Both I and Q paths. If you dont have 1% components measure each component and put equal value components in both paths.
regards
GV
yashiro32
Member level 1
What kind of effects will result when I and Q are mismatch ?
RFCMOS
Full Member level 2
France
HI,
mainly EVM degradation
jecyhale
Advanced Member level 1
China
If I and Q are mismatch, the image rejection will be reduce.
When amplitude mismatch increase 0.5dB the image rejection will reduce 5~10dB.
DDavid
Full Member level 5
please review the following paper!
David
symsnowfairy
Junior Member level 1
Germany
I and Q mismatch
"Unbalance in the RF splitter used to divide the incoming RF signal equally between the I and Q paths"
How does the RF splitter divide I and Q?
Bhanumurthy
Full Member level 5
Subcontinent
For the RF splitter to split the data into I and Q channels, a clock should be used as one of the inputs to the RF splitter.
bye
Bhanumurthy.
GVVIN
Bhanu,
could you pls provide more details (datasheet) of this special RF splitter which splits into I and Q
Regards
GV
Bhanumurthy
Full Member level 5
Subcontinent
GVVIN,
The details abt the special RF splitter can be found in the text book"Principles of Communications-Fundamentals through Advanced" by Wayne Tomasi.
bye
Bhanumurthy
