How to reduce second and 3'rd harmonic on low pass filter ?
jackie1116
Junior Member level 2
Does anyone have this experience with is .and i want to know,as below
(1) Increase orders in passive Low pass filter whether it can reduce the harmonic
(2) i use NPO cap. and hight Q inductor whether it can reduce the harmonic
(3)if i design LPF and HPF on one board,what is importance to reduce harmonic
Hope advancer can help me !
very thank a lot!
Re: How to reduce second and 3'rd harmonic on low pass filte
jackie1116,
The higher the order of a filter, the steeper the gain/frequency slope will be. So for a given cutoff frequency, a higher order filter will give more attenuation of harmonics. The ultimate slope of a low pass filter is 6n dB/octave or 20ndB/decade.
Higher Q inductors and capacitors will allow you to get closer to the ideal frequency response. Finite Q introduces additional resistive components that effect the frequency responce. The priniipal advantage of an NP0 caacitor is its small temperature coefficient of capcitance, although it does ave higher Q that other ceramic types.
Regards,
Kral
LaTeX Commands Quick-Menu:
