Hello All,
I am using the RN4678 Dual Mode Bluetooth module for my project. The connection and disconnection of the Bluetooth are reflected on the status pin P1_5 which indication that Bluetooth is connected to the peer device or not. I use this as the status indication pin in my program. "1" indicates not connected to peer device and "0" indicates connected to the peer device.
So I am sending per second data to the Android (using serial Bluetooth app over spp) over the Bluetooth. When I disconnect the RN4678 Bluetooth from the android then the status indication pin changes its state after the delay of 2/3 seconds. How to reduce or get rid of this 2/3 seconds duration as I don't want to lose any data?
As soon as I disconnect the Bluetooth from the android phone the status indication pin should change its status.
Thanks in advance
