How to reduce quiescent current in the bandgap circuit
kumard35b
Member level 5
Could anyone help to reduce the quiescent current in the bandgap circuit.
Regards
Kumar
Hi kumard35b,
Since your question is too general, I only give some general ideas:
First, you can try to use weak-inversion transistor to realize bandgap circuit.
Second, you can turn off bandgap circuit in power down mode if application allows.
regards,
jordan76
Make sure your startup circuit doesn't consume any power when it is started.
Yibin.
Yibin.
could you tell me startup circuit details, thanks!!
i want to know how to design it,
Let me be more specific..I have designed one Bandgap circuit ..for that i am getting a quiescent current of 35mA,the customer is asking me to reduce the quiescent current.
Could anyone propose any circuit or just lower the output resistance is enough.
decrease the structure ,i think is a way.
35 mA ? I think it is too large.
the bandgap core can be made < 100uA from many JSSC's paper,
refer to this
utilize large resistor to design reference operating point,but it will waste much layout area.
35mA? Did you design in bipolar process?If you design with bipolar process,I think you can decrease the quesicent current by increasing the sample resistor.
Large resistor is a good choice
35mA? my god. which process?
