usman
Junior Member level 3
Assalam o Alaikum to All!!!
i faced a simple problem while working on FPGA>>>i am using spartan2e FPGA & D2SB board, as u might know the clock speed of this FPGA is 50Mhz. i wanted to run a simple sequential component(JK FFP) on it, all the combinations of J&K input of JK Flip Flop works fine but when both input becomes 1 then output is not valid cause of high speed i don't see togling........so what should be done to see a clear togling on the output. in other words how to reduce the clock speed and use in my design....
regards,
Muhammad Usman
regards,
Muhammad Usman
