Re: Hi
when you get the timing violations, you may make sure:
1. the violations are real or not, firstly you should check your design constraint, such as clock definition, timing exception, environment setting etc...
2. if the violation are real, you should make sure that in the synthesis stage, you should solve all the setup violations by synthesis tools or communicate with the circuit designer. for the hold violation you can check them after CTS synthesis.
3. when in timing sign off stage, you also should analysis the Xtalk and OCV, of course the check corners you setted should adapt to your company i.e check all the corners when timing sign off.
