How to recharge a lithium battery pack ?
Externet
Advanced Member level 2
Mideast US
Hi.
A Hoover brand 18V battery pack with 5 cells has three terminals. (+), (-) and (C)
How to learn what signal this particular 'C' battery pack contact expects to enter into charging mode ? The pack uses a microcontrolled management circuitry in it.
For sure signal is not needed at 'C' to discharge the battery. It powers the load fine with nothing connected to 'C'
----> **broken link removed**
Am using this orphan pack for another application and do not have the charger. When applying 24V to (+) and (-) and jumping 'C' to (+) ; cells charge fine for 3 seconds, slowly raising voltage. Repeatedly jumping, they keep rising (charging) fine. Could the pack expect a pulsing signal to terminal 'C' ? Anyone knows ?
Read about the charging methods.
Read through battery manufacturer provided documents.
Read through batteryuniversity.com
Read through other informations.
At each source you will immediately learn that
...is not a good idea.
Klaus
I had read what you suggested and also found nothing from the manufacturer; that is why posted here if someone knew details.
The (+) and (-) terminals of the battery pack are not connected to the cell series; there is mosfets driven by the charging management circuit that 'modulate/control' charging according to each cell balancing status, voltage, current and temperature.
Similar to :
