Hi
I am simulating a parallel coupled bandpass filter with stripline structure in ADS2004A, but I can't find parallel coupled stripline with only 2 ports for the filter design.
The picture has been attached .
So, How can I realize the component of the parallel coupled stripline with TLines-Stripline in Schematic?
khouly,Your model likes being built in Microstrip line? if the figure attached is the equivalent circuit of the parallel coupled stripline with opposite port in different strip?
u can use and em simulator model the stripline geometry in that and analyse over desired frequwncy..u will get the S-Parametr file..this file u can import in ADS use it as a component defined by you analyse ur filter geometry
