How to realize a 0.5V output LDO ?
ken_cn
Member level 2
Dear all,
I want to design a LDO with 0.5V output. As I know, the output voltage is derived from the bandgap voltage by res devider. So it is easy to realize a LDO with output > 1.2V. But how to realize a 0.5V LDO? Could you give me some tips or papers about this topic?
Thanks.
B.R.
Ken
dick_freebird
Advanced Member level 5
USA
Sub-bandgap references exist, but at 0.5V -supply-
you are probably looking at low-VT ("natural"?) MOS
in a delta-VT scheme. If you only have diodes and
high-VT MOS, that'd be a tough one. What is your
minimum in-regulation supply voltage required?
If you have an auxiliary, higher supply (like I/O) you
might run the bandgap and pass device gate drive,
off that and only the output transistor off the low
voltage.
tdy
Member level 3
Navy
divide the Vbg by a res ladder
erikl
Super Moderator
Staff member
Germany
dick_freebird said:
... low-VT ("natural"?) MOS
Guess you think of native nfets (Vt ≈ 0) ?
Would be highly welcome ;-) for the voltage comparison!
dick_freebird said:
... only the output transistor off the low voltage.
Wouldn't the output transistor better be a pfet running off the in-regulation supply voltage?
dick_freebird
USA
Depends, a 0.5V output and (say) a 0.6V min input supply
only makes for P Vgs=-0.6V, which isn't going to give much
output current. But if he also has (say) a 2.5V I/O rail then
there's plenty of juice for a source follower output.
s in both N and P. Plus depletion mode that we aren't
allowed to use except as caps (though I have).
Hard to get a natural / native / intrinsic FET on a flow
that deposits epi doped in-situ though.
