How to read the timer 2 value into a variable in Keil C?
UroBoros
Advanced Member level 2
Cochin - India
little endian keil
Hai,
In Timer2 ISR I have a unsigned intiger variable.
How I can I equate the lower byte of the variable to TL2 and upper byte to TH2.
so that I can treat the variable as timer value
I think keil has got a method.not sure.
Please suggest
Thanks for the reply
Sorry for the mistake. my question was totally confusing.
Actually on the external interrupt from port3.6,I want to read the timer 2 value into a variable.(TH2 and TL2).
suppose I declare a variable
unsigned int timer2_val;
How can I move TL2 and TH2 into lower and upper nibble of timer2_val, so that I can treat Timer2 value as a single variable.
I am a beginner in C.
Thanks again
Picstudent
Re: Keil declaration Help!
try this:
unsigned int var, tmpHI, tmpLo;
tmpHi = var & 0xFF00;
tmpHi >>= 8;
tmpLo = var & 0x00FF;
TL2 = tmpLo;
TH2 = tmpHi;
Best Regards.
Mr.Cube
    UroBoros
If I'm understand well, you have TH2 and TL2 and you want to make one integer variable from those two.
timer2_val = TH2*256 + TL2;
or
unsigned int tmp;
tmp = TH2 << 8;
timer2_val = tmp + TH2
Mr.Cube
    UroBoros
try this:
#define HIGHBYTE 0
#define LOWBYTE 1
union
unsigned int timer16;
unsigned char timer8[2];
timer;
timer.timer16=0x1234; // the 16 bit value
TH2=timer.timer8[HIGHBYTE]; // highbyte of the 16 bit value
TL2=timer.timer8[LOWBYTE]; // lowbyte of the 16 bit value
Please note if you are using this on a PIC HIGHBYTE has to be defined as 1 and LOWBYTE has to be defined as 0.
best regards
    UroBoros
Re: ke*il declaration Help!
Picstudent said:
Hai,
Picstudent
if little endian order memory (Keil >4.0 or intel)
// define union
union WORDBYTE {
unsigned int two;
unsigned char one[2]; // one[0]=high one[1]=low
// declare variable
main()
union WORDBYTE timer2_val;
timer2_val.one[0] = TH2;
timer2_val.one[1] = TL2;
if(timer2_val.two >0xabcd) {
// your code here
if big endian order memory (Keil<4.0 or Motorola)
// define union
union WORDBYTE {
unsigned int two;
unsigned char one[2]; // one[0]=low one[1]=high
main()
timer2_val.one[0] = TL2;
timer2_val.one[1] = TH2;
// your code here
    UroBoros
