How to read the output of a module in VHDL (Xilinx) and use this as input?
lgdly
Newbie level 3
Lets say that the top level contains module X.
Module X has inputs A, B of std_logic_vector and outputs of C and D (also std_logic_vector).
Module X contains within its architecture (using component/direct instantiation) Module Y.
Module Y has inputs M, N of std_logic_vector and outputs E, F (also std_logic_vector).
How can I write my VHDL to describe:
The output of Module X (C for example) is the input M to module Y.
ie. Module X could be a FSM, which outputs an enable signal (C), and this is connected to input M of module Y.
When this is high, module Y can now perform its role (a counter for example, with input M being an enable).
In addition the output E of module Y is wired up to be the output of D of Module X
I currently get the error that Xilinx cannot read from an output and I should use inout/buffer, but this doesn't seem to work. If this question is too abstract I will update it with code and the error messages along with a schematic.
a. Use VHDL 2008 which allows reading of an entity's output port
b. Create a c_local signal and use that as the local output then assign it to c for the entity's output.
Is there any way around point a without using VHDL 2008?
Do you mind expanding point b please? I'm new to VHDL. Thanks
ie creating a c_local signal, is this an internal signal inside module X which is then assigned to module X output?
d. Declare the output port as "buffer". (Although IMO it's the least preferable option...)
Like this - create a local internal copy of the output :
Code VHDL - [expand]
8
9
10
11
12
13
14
15
16
17
signal op_i : std_logic_vector(7 downto 0);
process(clk, reset)
begin
  if reset = '1' then
  elsif rising_edge(clk) then
    op_i <= some_ip;
    if op_i = x"AB" then
      --do something based on output
   end if;
  end if;
end process;
op <= op_i;    -- connect output to local internal copy of output.
