How to read or write video file in verilog
kissmoh
Junior Member level 1
Hi im trying to make image processor using FPGA
i've read many sequence frame image files for simulation but dont know how to read video file(or write).
can someone teach me a sample code for it?
is there any specific format should be used? i want to read it and output the result video file after passing my module.
and how to capture and store the result image or video results showed to me through monitor?
video files are usually compressed, so you wont be able to read it into your Verilog. You need a raw format before you can read it into verilog. Text files are the easiest.
