Hello everyone,
I generated a binary file in Modelsim, wish to use it in Specter as stimulus: "0" -> gnd, "1" -> vdd, how to do it?
I have tried to use Vpwlf in analogLib, but get a Sawtooth wave, which is not what I wanted. I wish to get a pulse width modulated square wave. Many thanks for help! HJ
Thank you very much Pancao! I tried following your instructions, but still have confusions:
1) How to " include instance description of "vsource" as netlist" ? I didn't find "netlist" under any button in the vsource instance form.
2) Where to indicate the path to the file?
Many thanks.
Hi Pancao,
If I put vsource in the schematics, the generated netlist should already include the vsource. What is instance description? Really don't know what you mean
Also, how to let the spectre know the location of the file? Thanks for your time, will appreciate very much if you could make it more clear.
Thank a lot! I should use pdm. By searing spectre -h vsource, I found a thread in Cadence forum, said there is a file section in vsource form to indicate the path to the file. but I can't find it in the instance form, no matter vsource from analogLib or that from rfLib. Did Cadence remove this section?
I do remember I used this function long time ago when designing a sigma delta DAC, but forgot whether it was vsource or other thing.
