I like to just march the D input edges (must test both)
across the CK edge using the td param of a pulsed voltage
source. With a proper initialization of course. Use the
parametric analysis tool, or .MODIF (if a bare SPICE kind
of setup). Look at the Q waveform family-of-curves.
You will see the output act normally at large setup,
the CK-Q delay slide out, then flip to "wrong answer"
as you violate the setup time. Similarly (but opposite)
at the hold data edge.
Layer a delay measurement on this and you can get
a delay-vs-setup-time plot (although some delay
functions deal poorly with "didn't happen", as the graph
may be showing where there is no data). Criticize the
delay against what your digital timing model says is the
cell delay, or the delay you have been tasked to
achieve; the setup it takes to make the delay (plus
comfort margin) is your answer.
Be sure to use realistic D, CK edge rates as this has
some impact to the answer. Box it with min and max
(fanout+wireload) and process corners.
