[General] how to plot a data? (UART)
Plotproblem
Newbie level 3
Newbie level 3
Hey guys, i need a hand.
My movement sensor is sending data to PC through serial port ( UART )
Then i need to get that data and assemble to a variable and plot.
I need to receive the data and plot it.
I'm using Code Blocks to write the code, any ideias how to put it all together?
Thank you all!
My ideia was: trying to create a program, that plot the data in real time (while the data is collected).
My first ideia was to assemble the data to a variable, in the code, to make my program.
I need to write the program down, can't be ready made :(.
everything i tried it dont work, i tried to use koolplot library, graphics one, nothing worked.
I have used wxWidgets with Code::Blocks to plot graphs of data acquired from ADCs
https://www.wxwidgets.org/
the critial thing is how fast is the data arriving? if too fast (probably greater 200 or 300 samples/second) you could could start loosing data - I found that skipping elements, e.g. plotting every 5 or 10 samples, can hep but you loose information.
I'm also using wxWidgets, but i still dont know how plot using it.
yo're using wxwidgets to plot the data on real time?
How you do that?
it was some time ago but I seem to remember using wxPaint
https://docs.wxwidgets.org/trunk/classwx_paint_d_c.html
e.g.
void paintFrame::Paint(wxPaintEvent& event)
        wxPaintDC dc( Panel1 );
    dc.DrawLine( 0, 0, 100, 100 );
    printf("paint\n");
also worth looking at is wxSmith
https://wiki.codeblocks.org/index.p...al:_Drawing_on_the_Screen_and_Saving_Drawings
these days I tend to use Visual Studio either painting lines onto panels or using the Chart component
https://msdn.microsoft.com/en-us/library/dd489237(v=vs.140).aspx
