does HFSS have a seperate utility to plot the radiation patterns? I have the measured data and I want to plot it. The data is columnwise. Theta,Phi .vs Power. I want to plot these data in a 3D polar plot like the one MWS or HFSS does
Plotting polar patterns in Matlab could be proved very tricky
Matlab converts negative numbers to positive/180phase... 2D polar patterns need to be carefully converted before plotting...
Moreover, 3D polar patterns are impossible with Matlab... You have to convert to XYZ data points and then plot with 'surf' or 'mesh' commands... This could be very annoying when handling thousands of data-points (360X180)...
I have to agree with you after a lot of attempt with matlab. I wonder if there is any other more usefull plotting software for this purpose (3D polar plots of radiation patterns)
