Jun 12, 2005 #1 D davyzhu Advanced Member level 1 Joined May 23, 2004 Messages 494 Helped 5 Reputation 10 Reaction score 2 Trophy points 1,298 Location oriental Activity points 4,436 loop logic Hi all, It's intuitive to pipeline a feed-forward combinational logic. But how to pipeline the Loop without changing the timing? For example, when I insert a reg to feed-forward logic, shall I delete a reg in feedback logic at the same time? And if the datapath logic is a iteration one(Logic A -> Logic B -> Logic A -> Logic B ...)? How to do pipeline? Any suggestions will be appreciated! Best regards, Davy
Jun 13, 2005 #2 C claint Member level 5 Joined May 21, 2004 Messages 94 Helped 5 Reputation 10 Reaction score 2 Trophy points 1,288 Activity points 762 Is your logic DSP alogorithm related? If it is (for example,IIR filter) ,use clustered look-ahead , scattered look ahead method to translate the prototype algorithm to architecture. Generally, loop logic is not easilly pipelined.
Jun 14, 2005 #3 J JesseKing Advanced Member level 4 Joined Nov 12, 2004 Messages 100 Helped 3 Reputation 6 Reaction score 1 Trophy points 1,298 Activity points 838 I don't think inserting reg in loop without changing timing can be achieve, unless you use new algorithms.
