Please show the printscreens with steps and the printsceen when it fails showing the ERROR message.
Here are my steps and the relevant printscreens:
1. Implemented design in vivado and generated bitstream
2. export hardware including bitstream and launch sdk
3. Create new application with Zynq FSBL (figure below)
4. From Xilinx/ Create Boot Image, I have defined the path for the new boot file and named it BOOT.bif.Then I added the other files from this link. I doubt that I did a good job at this step or not?! I assumed that the files in this link are pre-built by Xilinx to bring up the processor and they're design independent! So, I just copied them for my design (figure below).
5.SDK Console reported the successful job by bootgen(figure below)
6. The BOOT.bin file was generated beside my other files (figure below)
7. Then I executed the following commands in XSCT Console and loaded my BOOT.bin file into the ARM processor, Core #0.
xsct% connect
xsct% targets
1 APU
2 ARM Cortex-A9 MPCore #0 (Running)
3 ARM Cortex-A9 MPCore #1 (Running)
4 xc7z045
5 whole scan chain (board power off)
xsct% targets 2
xsct% dow -data BOOT.bin 0x08000000
100% 28MB 0.5MB/s 00:55
Successfully downloaded /home/mostafa/Documents/Xilinx/test_designs/ZYNQ_zc706/ZC706_PCIe/ZC706_PCIe.sdk/upload/BOOT.bin
xsct%
In the next step when downloding the u-boot.elf file, I received this message:
xsct% dow u-boot.elf
Downloading Program -- /home/mostafa/Documents/Xilinx/test_designs/ZYNQ_zc706/ZC706_PCIe/ZC706_PCIe.sdk/upload/boot_image/u-boot.elf
section, .text: 0x04000000 - 0x040422db
section, .rodata: 0x040422dc - 0x04051bec
section, .hash: 0x04051bf0 - 0x04051c1b
section, .data: 0x04051c1c - 0x040541af
section, .got.plt: 0x040541b0 - 0x040541bb
section, .u_boot_list: 0x040541bc - 0x04054aa3
section, .rel.dyn: 0x04054aa4 - 0x0405df6b
section, .bss_start: 0x04054aa4 - 0x04054aa3
section, .bss: 0x04054aa4 - 0x046a991f
section, .bss_end: 0x046a9920 - 0x046a991f
100% 0MB 0.5MB/s 00:00
Setting PC to Program Start Address 0x04000000
Successfully downloaded /home/mostafa/Documents/Xilinx/test_designs/ZYNQ_zc706/ZC706_PCIe/ZC706_PCIe.sdk/upload/boot_image/u-boot.elf
xsct% Info: ARM Cortex-A9 MPCore #0 (target 2) Stopped at 0xffffff28 (Suspended)
__image_copy_start() at arch/arm/lib/vectors.S: 51
51: couldn't open "/scratch/skarandikar/fpga-zynq-staging_zctest/common/u-boot-xlnx/arch/arm/lib/vectors.S": no such file or directory
xsct% con
Info: ARM Cortex-A9 MPCore #0 (target 2) Running
xsct%
So, I supposed that my program was written into the processor, so I turned off the board and host PC, inserted the zc706 inside the PCI bus of the PC motherboard, then reastarted both zc706 and PC. When execusing lspci, the ZC706 was not recognized bt the host PCIe bus.
Am I doing something wrong? Unfortunately, the exampled inside the internet are very limited and vague! Can you please help me by this issue?
Thanks and Regards,
Daryon
