AndreyG
Full Member level 4
- Joined
- May 10, 2010
- Messages
- 196
- Helped
- 27
- Reputation
- 54
- Reaction score
- 27
- Trophy points
- 1,308
- Location
- Vancouver, Canada
- Activity points
- 2,946
Here is challenging little problem:
I have a circuit (current source) which I want to drive with combination of four independent analog signals. Sources of signals will be sound cards. The frequencies will be very low - fraction of Hz.
Because they are four independent sources I want to isolate the signals. I want to use optocouplers.
I want to make audio signal to drive optocoupler LED. And nothing else on the primary side of coupling circuit.
So far I cannot figure out how to do it. There are several complications: coupling should be reasonably linear, incoming signal is bipolar and I do not want to have to add power sources to power up primary side of coupling circuit (I have four such circuits which would mean 4 isolated power supplies – too much!) And the circuit should be inexpensive.
I discovered isolating amplifiers by Analog Devices that do all that I need. They are linear, work with bipolar signal, generate power on primary side from secondary side. But they cost upwards of $80 a piece (I need 4).
There are isolating amplifiers at $6 a piece but all require isolated power supply on primary side.
I discovered highly linear arrangements with opto couplers made with two integrated photo diodes providing feedback on primary side. Very neat but requires power supply on primary side.
I can connect LED’s of two optocouplers oriented oppositely and combine outputs from corresponding photo transistors – this will give me bipolar response to bipolar input. This does not require power supply on primary side. But I have a gap (dead zone) in the middle from ~-1 to ~+1Volts when diodes do not conduct.
The latest approach comes the closest to what I want. I can leave with some non-linearity no problem. The question is: how to eliminate the dead zone around zero when diodes do not conduct?
