How to operate 24V stepper motor using Spartan-3e?
BooM
Member level 4
Member level 4
hi,
I use the spartan 3e and I want to operate a stepper motor which has rated voltage 24v. So,my question is if I need an external source in order to actuate the motor or can I take from the fpga 24v??
Thank you in advance!
echo47
Advanced Member level 6
USA
spartan-3e
The FPGA I/O pins tolerate relatively low voltages and currents, around 3.3V and 25mA (see the data sheet).
You need a separate 24V power supply and some interface circuits to switch the motor's higher voltage and current.
BooM
Member level 4
Member level 4
Re: spartan-3e
hi echo
Thank you very much!
sprao
Member level 1
Member level 1
spartan-3e
If you want control your motor with such a large voltage (24V) then it is better to use opto couplers or buffers in between driver circuit (which will be made with darlington transistors/MOSFETs) and FPGA.
cheggy
Member level 5
Member level 5
Re: spartan-3e
Use DA converter controled with FPGA and output amplifiers for achieving 24V level.
BooM
Member level 4
Member level 4
Re: spartan-3e
thank you very much gays for your reply.
cheggy could you tell me more detailed your idea please? I am very new to FPGA.
cheggy
Member level 5
Member level 5
Re: spartan-3e
If U need to control voltage level U may send digital data from Your FPGA to DA converter, then buffer DA output and amplify it. In this manner U define the final (amplified) signal level by simply sending bigger/smaller digital number value from FPGA output pins to DA.
BooM
Member level 4
Member level 4
Re: spartan-3e
cheggy Thank you!!!!
I ll try to do it.
BooM
Member level 4
Member level 4
Re: spartan-3e
Oh!! I really sorry...I would write GUYS!!!!:D
