how to open s3p fle schemtic in ADS agilent
riz_raxi
Junior Member level 1
I am having a VSW2-33 SPDT switch. I have its datasheet. I know its pin numbers but i dont know where are the actual pins in s3p file which i got from its vendor. I need to open the schemtic of s3p file.
Thankyou
In dchematic you must select the element S3P from the Data Items Palette. In the properties of this element you choose:
1. in "Parameter Entry Mode" - "Network Parameter filename"
2. in "File Name" - you point out a path to your file *.s3p
3. and take up "Edit"
