Does anyone have some resources or mind explaining to me how we can synthesize a Chebyshev filter from the formulas specifically, and not from tables?
Specifically, I did the long form calculations starting with minimum number of poles and so forth, however, when I get to Gvalues G1, Gn I get complex numbers of which I am not sure how to realize into a component value. I was hoping someone could walk me through the design process.
Filter Topology: Chebyshev Low Pass
Gp (Ripple): -1dB, fp: 13.56MHz
Gs: -40dB, fs:27.12MHz (2nd Harmonic)
These values really are arbitrary, and I am only interested in completing the formula for future synthesis and understanding so if you have an example with different values that is fine as long as they are stated.
First off I did the equations for the minimum number of poles:
Npoles = 1/(acosh(fs/fc) * acosh(sqrt((10^-(Gs/10) -1)/(10^-(Gp/10) -1))
Npoles = 1/(acosh(27.12/13.56) * acosh(sqrt((10^-(-40/10) -1)/(10^-(-1/10) -1))
Npoles = 4.53611, Since we cannot realize a filter with fractional poles we round UP. Npoles = 5.
ε^2 = 10^-(Gp/10) -1 = 0.25892541179
We can then verify our transfer function? to make sure the number of poles produces the desired attenuation with the following formula:
|G(f)|^2 = 1/(1+ε^2*cosh^2 [Npoles *acosh(fs/fp)]
|G(f)|^2 = 1/(1+0.258925*cosh^2 [5*acosh(27.12/13.56)] = 2.947108E-5 = 10*log(2.94E-5) = -45.3dB at 27.12MHz which is better than our -40dB minimum.
Now if we take this and turn it into our further values B, Y, A1, G1 etc I get complex values. How do I turn these complex values into component values for systems using only LC components?
I am NOT interested in using precomputed tables I am only interested in learning the actual formula and method behind MANUAL synthesis of the filters. This is purely an exercise in learning and understanding how they are realized using mathematical processes.
Sources:
https://en.wikipedia.org/wiki/Chebyshev_filter
https://www.matheonics.com/Tutorials/Chebyshev.html
https://en.wikipedia.org/wiki/Electrical_resistance_and_conductance
https://en.wikipedia.org/wiki/Electronic_filter_topology#Ladder_topologies
https://web.njit.edu/~gilhc/EE494/tutorial.htm#ChebyshevFilters
Microwave Filters, Impedance-Matching Networks, and Coupling Structures [George L. Matthaei] pg 97 on
