How to modify the cadence IC5141 window font color?
jackpeng
Newbie level 3
Newbie level 3
china
help how to change the font color of IC5141
hello·i need you help~:how to change the font color of IC5141 ?like this QQ截图20150507110850.pngplease
Re: help how to change the font color of IC5141
Basically the way you do this is to edit your cds.lib file. Somewhere after the DEFINE statement for a library, put the line:
ASSIGN <libName> DISPLAY <displayName>
where <displayName> is the name you're going to give to a particular set of display attributes
Now when you open the Library Manager, select Edit->Display Settings. In that form, you'll be able to select your <displayName>(s) and change their colors, icons and other attributes.
