How to model a varistor and a variable capacitor in ads
Marios91
Junior Member level 3
Kalamata
Hello,
i would like to know how i can model a varistor and a variable capacitor depending on voltage.
thanks in advance
The value of capacitance drops only slightly as voltage is applied to the varistor. As the voltage approaches the nominal varistor voltage, C drops abruptly and R approaches a fixed ESR value.
Wheras diodes, i believe the C²V product is a constant figure of merit as well as tolerance for reverse bias with C limits at -1V depending on power rating and conductor gap. Normally varicaps are rated by C1/C2 ratios at V2, V1 like C1-30 ratio for 1-30V....
Hello,
thanks in advance
Check the elements on the "Eqn Based-Nonlinear" palette. There you find general equation-based elements and a non-linear capacitor.
