Jan 7, 2008 #1 T tukken Member level 2 Joined Nov 29, 2004 Messages 46 Helped 1 Reputation 2 Reaction score 0 Trophy points 1,286 Activity points 550 vcd merger I have 2 vcd file, and 1 is for top level, and other is a sub block vcd file, how to merger 2 files into 1 vcd file. Thanks.
Jan 7, 2008 #2 A aji_vlsi Advanced Member level 2 Joined Sep 10, 2004 Messages 643 Helped 85 Reputation 170 Reaction score 12 Trophy points 1,298 Location Bangalore, India Activity points 4,944 merge vcd files tukken said: I have 2 vcd file, and 1 is for top level, and other is a sub block vcd file, how to merger 2 files into 1 vcd file. Thanks. Click to expand... If you use VCS, it has an utility named vpdmerge to do this (you can convert VCD to VPD using vcd2vpd). I believe Modelsim also has similar utility. Regards Ajeetha, CVC www.noveldv.com
Jan 8, 2008 #3 T tukken Member level 2 Joined Nov 29, 2004 Messages 46 Helped 1 Reputation 2 Reaction score 0 Trophy points 1,286 Activity points 550 vcd2fsdb Thanks. How about verdi, nawaves
Jan 8, 2008 #4 T TerryC Newbie level 1 Joined Jan 8, 2008 Messages 1 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,283 merge vcds Verdi has similar utility as "vcd2fsdb".
Jan 8, 2008 #5 A ameed Advanced Member level 4 Joined Jun 28, 2007 Messages 106 Helped 6 Reputation 12 Reaction score 1 Trophy points 1,298 Location INDIA Activity points 1,931 vcd verdi attachment files are given.
Feb 19, 2009 #6 J jonyRoyal Member level 1 Joined Apr 24, 2006 Messages 40 Helped 7 Reputation 14 Reaction score 4 Trophy points 1,288 Activity points 1,471 verdi vcd2fsdb verdi has utility called fsdbmerge Usage fsdbmerge: fsdb_file_name [options] -o merged_file_name
Feb 19, 2009 #7 U user1111 Member level 3 Joined Mar 24, 2007 Messages 55 Helped 7 Reputation 14 Reaction score 2 Trophy points 1,288 Activity points 1,576 merge vcd you can just create movie from two vcd files using movie maker or nero. or you can use total video converter to combine
