How to measuring small DC signal by ADC in PIC or AVR?
hongphuc118
Member level 2
Ha Noi,Viet Nam
I want to measure the DC signal which max Volt = 2mV.
Can you show me how to do this?
is your signal is regulated or nmon regulated.
if it is non regulated then use a very small ref voltage about 25mV.
but i'm not sure about the output!......:?:
For AVR you can't use such a low Vref, for example in mega8 the min Vref is 2v , for mega88 it is 1v
Alex
Amplify the signal so that the range of the signal matches the input range of the ADC.
Connect a signal conditioning circuit after receiving signal. Which basically will be a buffer or a linear voltage amplifier( say an Op-amp). Then use that voltage as input to uC
Can you send me some examples schematic?
It is regulated.
connect an Op-amp in non-inverting configuration with a gain of 10 or 100 to amplify, followed by a buffer. and feed that input. be careful that the voltage does never increase the voltage (Vdd) of uC. So, i recommend use a amplifir with gain of 10.
Hello!
For op-amps, you may consider the following document which explains
almost everything you need to know for daily use of op-amps.
Dora.
