Dijskstra
Newbie level 5
- Joined
- Jun 28, 2014
- Messages
- 9
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 93
I'm trying to measure a pulse duration and I wrote the code below.
I'm simulating the pulses by pressing one push button, so, the pulse durations are multiple of seconds (not miliseconds nor microseconds)
What I want is the following:
1 - When a press a button, the counter resets
2 - While I'm pressing the button, the counter (pulse duration) increments
3 - When I release the button the counter shows it's content (pulse duration) in a row of 7 leds.
I've tryed the following code: (I know this is a very naive code, but I'm a beginner)
And I get the error:
ERROR:Xst:827 - "C:/VHDL/Pulse_Duration.vhd" line 31: Signal count cannot be synthesized, bad synchronous description. The description style you are using to describe a synchronous element (register, memory, etc.) is not supported in the current software release.
Can you please help me ?
Thank you
Anders
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity Pulse_Duration is
Port ( clk,
Button : in std_logic;
Led0,
Led1,
Led2,
Led3,
Led4,
Led5,
Led6,
Led7 : out std_logic
-- Display : out std_logic_vector(7 downto 0)
end Pulse_Duration;
architecture Behavioral of Pulse_Duration is
signal temp: std_logic_vector(7 downto 0);
begin
process(clk, Button) -- <---------------------- THIS IS 'line 31'
constant DIVISOR : integer := 50000000; -- 50 MHz clock => Xilinx Spartan 3e
variable count : integer range 0 to DIVISOR-1;
begin
-- button pressed
if rising_edge(Button) then -- 'Button' is asynchronous from 'clk' and must have priority over 'clk'
temp(0) <= '0';
temp(1) <= '0';
temp(2) <= '0';
temp(3) <= '0';
temp(4) <= '0';
temp(5) <= '0';
temp(6) <= '0';
temp(7) <= '0';
-- temp <= "00000000";
else
if rising_edge(clk) then
if count=DIVISOR-1 then -- see if counter == 49999999
count := 0; -- reset counter
temp <= temp + 1; -- increment pulse duration
else
count := count + 1; -- increment counter
end if;
end if;
end if;
end process;
process(Button)
begin
if falling_edge(Button) then -- Button released, then pulse duration displayed
Led0 <= temp(0);
Led1 <= temp(1);
Led2 <= temp(2);
Led3 <= temp(3);
Led4 <= temp(4);
Led5 <= temp(5);
Led6 <= temp(6);
Led7 <= temp(7);
end if;
end process;
end Behavioral;
Thank you
Anders
