What do you want to mean by "Cpar" ?But how do I get the Cpar of the inverter (that is-the internal capacitance).
This is not inverter.Please see attached picture for inverter.
Cadence Spectre has no relation to Cpar at all.I am using Cadence Spectre - how would I set these simulations up ?
Of course, very wrong.Please correct me if I am wrong.
No.I understand properly
Cpar has no relation to simulation.Also, Cadence Spectre is a simulator.
Just letting you know that.
No.This value has to be derived from simulation.
It sees an input of second inverter.I think OP is trying to determine the Cload seen by the first inverter by simulation means.
It is not Cpar.
Simply Puppet123 can not understand basic things at all.But at this point we don't know what OP has in mind...
Use Cadence QRC or Assura from layout not schematic.In principle, one can do this manually,
by going through a post-layout netlist,
Or one can use specialized EDA tools to do that (and much more).
I mean simulator has no relation to measuring of Cpar or simulator can not measure Cpar.so saying that they have no relation to simulator is not correct.
