Lucast85
Member level 3
Hello,
I need to measure the leakage current of an embedded board under test (DUT).
The DUT is powered by a custom voltage generator board that supply a voltage in the range [0-5] V. The voltage generator must measure both current and voltage, like a SMU. I'm looking for advice about the current sensing.
The voltage is sensed at the load and there is a feedback to compensate voltage drops along cables and other components; thus I could not worry about voltage drop across the current sense resistor (shunt resistor).
I expect a leakage current to measure of a few micro-ampere (I think in the range [1-7] µA).
Those are some desired specifications to design a current sense circuit:
However I can disconnect the DUT and compensate for Voffset, Ibias, and other stuffs (reading ADC's value and clear it from the measure via software) before to measure the DUT leakage current.
Is this the right procedure?
Have you got some advice to reach the goal?
Thanks in advance and excuse me for my bad english
- High-side current sensing; common-mode voltage expected in the range [0-5] V;
- Leakage current to measure range: [0-1] mA (unidirectional);
- Accuracy: ±2 µA;
- Resolution: 200 nA;
- Resolution of ADC: 16 bit in range [0-3.6] V;
- No rail-to-rail output;
- high voltage offset;
- high bias current;
