How to measure and improve PSRR in opamp design
dayang
Newbie level 6
My target is to design a opamp in 180nm 1.8v power supply.The input and output need rail to rail.My question is about the PSRR,How to measure it(use a close loop configuration or a open loop configuration)? How to improve it(just simply increase the channel length? is there any guideline about it ? I have read the posts here but still not understand it clearly, Help!!
REGARDS
Re: Help in Opamp Design
it could be improved by using cascade cofigurations that shield the circuit from power supply ...
The question is that when you use a rail to rail input configuration , there is not enough vlotage to hlod the cascade current mirror to work correctly.
dayang said:
REGARDS
PSRR=20*log(ΔVout/ΔVcc)
so use closed loop, introduced AC signal at VCC and then probe Vout
Btrend said:
dayang said:
REGARDS
Yes ,I got it and final PSRR is about 31dB, thank you very much
