Making the Via bigger
Hi friends,
I'm trying to design a board using Allegro Cadence V15.2. In the layout section, am not able to increase the size of the via. When I've added the via, it's very small and I'm not able to make it bigger. I'm not sure if I can do the same. And, I've seen this option and couldn't understand this. When I go to
Setup -> vias -> Define B/B Via (or) Auto Define B/B Via
I couldnt understand what B/B Via means. However, my primary concern is making the Via bigger. Let me know if you have any suggestions. I appreciate your support.
