Hi, it seems that you can not design the thickness in the pcb design software, what you need to consider is that which total thickness should be better for your board and that if it is multilayer pcb, then you should know the inner/outer copper thickness and which kind of PP should be used. Then inform all this information to the manufacturer.hii all,
How to make different thickness in same PCB(eg: 1.6mm and 1mm)? and 1mm thickness should be in round shape.I am using altium designer 14.1.
thanks.
Perhaps if Edabs came back and explained his original question, gave more information on what is wanted then it would be clearer to us?
I asked them for a quote last week, and they're prohibitively expensive for small prototyping volumes. Was around 1000 EUR for a 4 x 8 rigid flex board without special features like 2.5D milling (as suggested by FvM).Have a look at Wurths PCB site.....
