Apr 8, 2004 #1 abdoeng Advanced Member level 2 Joined Feb 22, 2004 Messages 647 Helped 76 Reputation 152 Reaction score 63 Trophy points 1,308 Activity points 3,810 phased array design -job -ieee -patent hi i would like ask about design of quasi yagi phased array,how i make phase shift between element using microstrip line technique regards
Nov 3, 2010 #2 P project.email Member level 4 Joined May 25, 2007 Messages 77 Helped 8 Reputation 16 Reaction score 8 Trophy points 1,288 Activity points 1,845 first you should define m-port (the number of port is m) then for each port you define a waveport or lumped port excitation and then from this root you can define phase shift between your port: HFSS>Field>edit sources
