angy
Full Member level 3
I have a Mil STD PCB with SMD components mounted on it.It was tested for 500G Shock test and dry solder problem on one of SMD resistor (2512)package occured.It was replaced with new one. Again 500G test was performed this time some other SMD resistor was the cause(maybe dry solder) .It was resoldered again.It will now be the last trial.
So i want to make sure everything is O.K.So i need suggestion as to what steps are needed to make sure it passes the tess this time? Also It will be helpfull if someone can recommend some adhesive to be used in component against shock and vibration
