How to make LCD texts to move either to the right or the left?
caramelz
Junior Member level 2
Hi guys. I want to make text in LCD to move around. i know is about shifting but due to my poor skills in microcontroller, i not able to do so. Please help.
here is the code i'm having.
#include <p18f4520.h>
#include <delays.h>
void Init_LCD(void); //Initialise the LCD
void W_ctr_8bit(char); //8-bit Control word for LCD
void W_data_8bit(char); //8-bit Text Data for LCD
#define LCD_DATA PORTD
#define LCD_RS PORTBbits.RB1
#define LCD_E PORTBbits.RB2
unsigned char LCD_TEMP,i,j,k,m;
char MESS[8]="welcome";
void main()
ADCON1=0x0f;
TRISB=0b11111001; // Port D as LCD data output
TRISD=0b00000000;
Init_LCD();
for(i=0;i<7;i++)
W_data_8bit(MESS);
/* LCD display initialization */
void Init_LCD()
W_ctr_8bit (0b00111000); //Function Set - 8-bit, 2 lines, 5x7
W_ctr_8bit (0b00001100); //Display on, cursor on
W_ctr_8bit (0b00000110); //Entry mode - inc addr, no shift
W_ctr_8bit (0b00000001); //Clear display
W_ctr_8bit (0b00000010); //Return cursor to home position
/* Write control word to LCD */
void W_ctr_8bit(char x)
LCD_RS = 0; //Logic '0'
LCD_E = 1; //Logic '1'
LCD_DATA= x;
LCD_E = 0; //Logic '0'
Delay10TCYx(50); //1ms delay
/* Write text data to LCD */
void W_data_8bit(char x)
LCD_RS = 1; //Logic '1'
LCD_DATA = x;
Which Compiler are you using? It is very easy with mikroE Compilers. For other Compilers you have to write Code. Left/Right Shift shifts all the lines of LCD. If you want to shift line 1 text then after it shifts both lines restore the second line to earlier text.
I am working on that code. If I succeed I will post the code.
i'm using MCC18
